Stast Steady Ping
fae7787
 Share
  On 2/4/2024 at 6:59 PM, fae7787 said:
Ho fatto molti test da quando me l hai detto e col cerchietto nell oceano con ping assist a 0 riesco ad ottenere delle partite sui server che ho aggiunto per efotball.
Adesso volevo provare a merre un intervallo di 0-13 ms
Expand
Oh I see, so it forces you to connect to servers you have manually allowed. Understood thanks, I'll pass it along to the team.
  On 2/4/2024 at 7:53 PM, Damiano Calafiore said:
@Netduma Fraser la geolatenza a cosa serve ?la funzionalità di quel filtro?
Expand
Of Ping Assist? To allow you to specify games you want to connect to that fall within a certain ping range e.g. 10 - 30ms
  On 2/4/2024 at 10:40 PM, Damiano Calafiore said:
 @Netduma Fraserla mia domanda era rivolta la geo-latency-a che cosa serve?-io gioco ad efootball .va utilizzata off oppure on ?
Expand
It's just a different way of filtering which is controlled in the same way, using your radius so if one doesn't work well try the other
  • 8 months later...
There will be multiple servers clustered together in a location so you'd only be blocking one of a few in that location - as you can see on the map, the one you denied it showing with an X but the one you're connected to isn't.
  • 3 weeks later...
Expand
Come dicevo nel mio precedente post :
Stavo provando a usare solo i server di torino per efotball facendo quel riquadro in verde ,ma mi butta inesorabilmente sempre e solo verso MILANO.
Ti allego anche le impostazioni-
Are you changing the Geo-Filter settings while you're already on the game? If so that will be why. Make a change then restart game or wait 10 minutes (in the lobby in the game). If that doesn't work, reboot PC/Console and it should work then.
Expand
" Are you changing the Geo-Filter settings while you're already on the game? " No
"Make a change then restart game or wait 10 minutes (in the lobby in the game). If that doesn't work, reboot PC/Console and it should work then."
Yes , sono tutte cose che gia faccio , ma senza risultati
Expand
After a new reset of r3 the only method than only work is the filter on the ping.
  On 11/1/2024 at 4:41 PM, Netduma Fraser said:
There will be multiple servers there, you'll need to keep blocking them, we'll look into the filtering of the game but may take some time
Expand
Ti confermo che anche mettendo i server in "negati " mi vengono selezionati per creare delle partite.
Naturalmente avviene anche dopo riavvio della playstation.
Devo aprirvi un ticket ?
Grazie mille per tutte le info che ci date
We're pretty sure the game is using relay servers which will be hard for us to resolve which is why it will require dev input, it may not be possible. We don't have a public ticket system, what you've done is fine thank you.
Expand
What is a relay servers?
 Share
