Robert Posted January 24, 2024 Share Posted January 24, 2024 I was wondering if you should reboot your R3 each day before you game to refresh the connection as when I check my speed it goes out of sync which leads me to my next question is it best to change my ISP modem for an off the shelf modem as my router kicks my Internet every so often I contacted sky with this and they say it's the gaming router that's not compatible with sky's router I know this is false. My last question is after every game should you be ticking allow and deny after every match depending on how the game went thanks I did msg Fraser private for help but a think he's got alot on Link to comment Share on other sites More sharing options...
swippur Posted January 24, 2024 Share Posted January 24, 2024 I don’t think anyone ever tested this.. this is just an old saying to power cycle your network equipment every once in awhile. The best way to do it is to unplug power from the outlet Link to comment Share on other sites More sharing options...
SamT98 Posted January 24, 2024 Share Posted January 24, 2024 Just now, swippur said: I don’t think anyone ever tested this.. this is just an old saying to power cycle your network equipment every once in awhile. The best way to do it is to unplug power from the outlet Bang on the money, if this was tested then they need to fire anyone involved within the testing procedures. Far too many issues with this, does make me wonder why they sold with a discount straight away! Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted January 26, 2024 Administrators Share Posted January 26, 2024 On 1/24/2024 at 12:04 PM, Robert said: I was wondering if you should reboot your R3 each day before you game to refresh the connection as when I check my speed it goes out of sync which leads me to my next question is it best to change my ISP modem for an off the shelf modem as my router kicks my Internet every so often I contacted sky with this and they say it's the gaming router that's not compatible with sky's router I know this is false. My last question is after every game should you be ticking allow and deny after every match depending on how the game went thanks I did msg Fraser private for help but a think he's got alot on It's not required to reboot the R3 every day, how is the speed going out of sync exactly? When the internet goes down do you still have internet when directly connected to the hub? You could allow/deny every time you finish a match, it certainly would be a good way to eliminate any bad servers and leave yourself with just the good ones. It's not necessary to do so but should work well. Link to comment Share on other sites More sharing options...
