Netduma R3 Geo Filter not working for Warzone / Mw3 , goes outside my filter range
I recently got my R3 and the geo filter is not working , I updated the firmware to .23 , factory reset it after a day and tried again , resync the cloud multiple times , it just keeps trying to connect within my filter (New York / Phili ) and then goes outside to Chicago and other locations. Is this a bug ? it seems to be working the 2 days ago upon receiving my router and now it shows the servers in New York and others as triangles / blocked but eventually goes to one. Is this a known issue and fix coming with firmware ?
I've tapped on a few other servers and added them to the block list, I'm in UK and was frequently connecting to Holland just outside my polygon, one time it connected to France too, this seemed to make a difference last night, don't know if that helps
  • Disable GeoLatency
  • Disable PingAssist (set it to 0,0)
  • Enable Strict Mode
  • Disable Fast Search
Then restart game or wait 10 minutes (in the lobby in the game). If that doesn't work, reboot PC/Console and it should work then.
@Netduma FraserI disabled it, and it worked for me. Another thing I noticed is that I can't select the game when I choose the device I'm playing on it always defaults to 'ALL GAME CONSOLE.' Are there other ways to specifically select the game I choose? I'm using Xbox Series X.
