Nycmaderey Posted January 13, 2024 Posted January 13, 2024 I have Verizon 1 gig plan with nighthawk xr1000 and I have latency issues I need a walk through step by step for best settings to minimize latency. I play nba2k24 and I’m experiencing noticeable issues. Please help.
Brandflakes08 Posted January 13, 2024 Posted January 13, 2024 Go to your Geo filter select a spot in the middle of the ocean and set distance to the minimum and set ping assist anywhere from 30-50ms.(Like the Photo attached) This will prioritize servers as close to this latency as possible. You can try QoS go through the auto setup and leave it on auto-enable.
Nycmaderey Posted January 13, 2024 Author Posted January 13, 2024 What should I put for my bandwidth allocation to my console?
Administrators Netduma Fraser Posted January 13, 2024 Administrators Posted January 13, 2024 I'd recommend having a look through our Optimal Settings Guides, that should help a lot https://support.netduma.com/en/support/solutions/folders/16000090646
