Davidt828 Posted February 2, 2024 Posted February 2, 2024 4 minutes ago, Netduma Fraser said: It doesn't prevent jitter, it raises the ping to absorb it so that you have a consistent ping throughout the match, do you see that? No the consistency is the same on the valorant ping graph as steady ping off just with a higher ping.
Administrators Netduma Fraser Posted February 2, 2024 Administrators Posted February 2, 2024 1 hour ago, Davidt828 said: No the consistency is the same on the valorant ping graph as steady ping off just with a higher ping. Could you provide a screenshot of what you're seeing when it's showing that it's stabilizing but you're seeing this inconsistency?
Davidt828 Posted February 3, 2024 Posted February 3, 2024 3 hours ago, Netduma Fraser said: Could you provide a screenshot of what you're seeing when it's showing that it's stabilizing but you're seeing this inconsistency? Question really quick do you have to have it added on the geo filter for steady ping to work or as long as you have steady ping on it doesnt need to be one of the 4 devices?
Davidt828 Posted February 3, 2024 Posted February 3, 2024 3 hours ago, Netduma Fraser said: Could you provide a screenshot of what you're seeing when it's showing that it's stabilizing but you're seeing this inconsistency? Here are some pics first is with steady ping off. The rest with it on.
Administrators Netduma Fraser Posted February 3, 2024 Administrators Posted February 3, 2024 13 hours ago, Davidt828 said: Question really quick do you have to have it added on the geo filter for steady ping to work or as long as you have steady ping on it doesnt need to be one of the 4 devices? No it doesn't but I think it should function that way, right now it applies to any device that is gaming, whether it is added or not. The jitter there is really minimal so that looks fine to me
Davidt828 Posted February 3, 2024 Posted February 3, 2024 59 minutes ago, Netduma Fraser said: No it doesn't but I think it should function that way, right now it applies to any device that is gaming, whether it is added or not. The jitter there is really minimal so that looks fine to me But is there any benefit to having it on in my situation or is it better to just have the it off and lower ping since I have fiber?
L0rd Posted February 3, 2024 Posted February 3, 2024 Ping optimizer makes bufferbloat worse. it sets itself too high. when i manually reduce CQ to like 55% DL / 80% UL i get A+ BB scores
Davidt828 Posted February 3, 2024 Posted February 3, 2024 I feel that with how low my jitter and ping is to start that the my ping graph in game should literally be a straight line but it seems to have to have the same consistency as having it off.
Administrators Netduma Fraser Posted February 3, 2024 Administrators Posted February 3, 2024 1 hour ago, Davidt828 said: But is there any benefit to having it on in my situation or is it better to just have the it off and lower ping since I have fiber? 40 minutes ago, Davidt828 said: I feel that with how low my jitter and ping is to start that the my ping graph in game should literally be a straight line but it seems to have to have the same consistency as having it off. It's hard to say without the graph showing properly but it is only adding a 5ms delay so that's the maximum it's seeing that it is fluctuating and your ping is low anyway so you probably could disable it and not notice the fluctuations much. 44 minutes ago, L0rd said: Ping optimizer makes bufferbloat worse. it sets itself too high. when i manually reduce CQ to like 55% DL / 80% UL i get A+ BB scores It will change what it suggests depending on the time of day etc so may not always provide the best value for a whole day if you see what I mean.
Davidt828 Posted February 3, 2024 Posted February 3, 2024 20 minutes ago, Netduma Fraser said: It's hard to say without the graph showing properly but it is only adding a 5ms delay so that's the maximum it's seeing that it is fluctuating and your ping is low anyway so you probably could disable it and not notice the fluctuations much. It will change what it suggests depending on the time of day etc so may not always provide the best value for a whole day if you see what I mean. I see that it says server tick rate synchronization is that more of a benefit or would you say having the lower ping with steady ping off is more beneficial?
Administrators Netduma Fraser Posted February 3, 2024 Administrators Posted February 3, 2024 31 minutes ago, Davidt828 said: I see that it says server tick rate synchronization is that more of a benefit or would you say having the lower ping with steady ping off is more beneficial? Matching the tick rate is definitely beneficial, it's better to be in sync than without it. Play with it both enabled/disabled and see which works best fpr ypi
Davidt828 Posted February 3, 2024 Posted February 3, 2024 2 minutes ago, Netduma Fraser said: Matching the tick rate is definitely beneficial, it's better to be in sync than without it. Play with it both enabled/disabled and see which works best fpr ypi thank you I appreciate it i think I will keep it on and side note for anyone having trouble with ping optimizer/congestion control not working make sure after you factory reset you restart your modem/ that is in front of your r3 before setting up the r3 again. Netduma Fraser 1
Davidt828 Posted February 3, 2024 Posted February 3, 2024 or if cc seems to break randomly instead of restarting the r3 restart the modem/router in front of the r3
