euphidra Posted January 4, 2024 Posted January 4, 2024 @Netduma Fraser Hi Fraser, I downgraded from version 4.0.23 to 4.0.20 (automatic update from 4.0.16). I've only done two reboots without any factory resets with each firmware update. Version 4.0.21 and 4.0.23 are not good. Smartboost doesn't work and not even on 4.0.20. 4.020 does not ping on the servers and does not show the steady ping graph but stabilizes it (which does not happen on 4.0.21 and 4.0.23). I hope you have a new firmware to send me and who knows a beta with Hybrid VPN to try like on Netduma R2. Thank you.
euphidra Posted January 4, 2024 Author Posted January 4, 2024 @Netduma Fraser Version 4.0.23 Test with Pingplotter Free. Each step of Pingplotter is 7.5ms. I set the steady ping on expert to 50ms. Is that right? Congestion is at 70% download and 70% upload at ALL TIMES. The steady ping simple mode automatically pings at 8 - 10ms? I play Efootball 2024 on Playstation 5 (Put on Playstation and not Game Consoles). R3_2024-01-04T19_02_46.572Z_logs.txt
Administrators Netduma Fraser Posted January 5, 2024 Administrators Posted January 5, 2024 As there has been a few versions I would suggest doing a factory reset as it'll likely work much better. Simple is 8-10 yes, expert yes it should be slightly higher than the ping you receive normally euphidra 1
