I have no upload limitation even when QoS is enabled.
Attaching screenshots from DumaOS and SpeedTest
Just now, Netduma Fraser said:
Are you using PPPoE/VLAN or IPv6 by any chance?
I have PPPoE connection
That'll be the reason then, it's something we're working on so if you have the ability to have your ISP modem/router handle PPPoE in the meantime I would recommend that
We don't give out any ETAs unfortunately, it's been an issue for a little while, 3.3 will be coming soon and then we'll be focusing more on bug fixes
