  • Disable GeoLatency
  • Disable PingAssist (set it to 0,0)
  • Enable Strict Mode
  • Disable Fast Search
Then restart game or wait 10 minutes (in the lobby in the game). If that doesn't work, reboot PC/Console and it should work then.
11 hours ago, pyroass said:
Also, from today, i cannot see anything in ping heatmap.
I am having the same issue brother with EAFC 24. i have created the video on this for my channel. i dont even have server list for the game.
Sorry for the delay, I will respond to you in your topic
Try this, remove the console from the Geo-Filter and in the Device Manager change it to a PC then re-add it to the Geo-Filter, does it work better then?
Great to hear that. Not yet, there will be a big meeting on Monday about bugs to organize what should be a priority, I suspect that's linked to a few issues so will be looked at quickly
1 hour ago, pyroass said:
@Netduma FraserIl semble que pour la PS5, cela fonctionne si vous créez une nouvelle connexion filaire. Solution de contournement 🙃
What do you if you create a new connexion ?!
The ping it's higher with r3, and it's fluctuate. Let's say my usual ping it's 25-27 with my old router. With r3 I have between 28-35.
My method works only to apply the geo filter with a new connection.
14 hours ago, pyroass said:
@Netduma Fraserseems for ps5 it's working if you create a new wired connection. Workaround 🙃
What do you mean by create a new wired connection? On the console make it search for a connection via ethernet?
yes, exaclty. i need to remove the old connection in my ps5 and after that to create another one.
Interesting okay, thanks for that, I'll keep it in mind and pass it along to the team in case it has any significance!
Hello, @Netduma Frasergeo filter not working anymore. i tryied reboot, 10 minutes wait in loby, new connection, remove/add ps5 in geo filter. it's the new version available?
What's it doing now? Nothing later than .23 currently, the team are working on it.
it's connecting only on the servers out of the cercle in this moment. need to reboot all the time when this happen.
5 hours ago, pyroass said:
Have you ETA to fix the ping fluctuation? and the other problems?
Is that after doing the steps at the top of this page?
New firmware should be this week or early next, I don't know what this version will have in it specifically yet but more firmware will come
30 minutes ago, pyroass said:
Yes, after all the above steps it's the same.
Are you changing settings while you're already on the game?
I also noticed a new problem. The ping displayed on the router with the servers of it is not true. it is a total lie. on all servers I have somewhere between 18-22 on the router and in game on some servers I have 30, on others 100, on others 60.
New firmware should be early next week. That's either Steady Ping or the in game ping includes processing delay, all games have it but not all choose to include it in their ping calculation. It's not something we can calculate. If the in game ping is up to 30ms higher roughly then the game should play well, anything higher than that could indicate the server is under heavy load and it's best to try to force a different server.
The 100 possible could be that it's using a relay server, we'd need to investigate that.
