clarkjo Posted June 5, 2024 Author Share Posted June 5, 2024 on the latest version it seems to be a little more inconsistent with how fast it connects, but there is still a delay. some days its 10 seconds other days its 30. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted June 6, 2024 Administrators Share Posted June 6, 2024 15 hours ago, clarkjo said: on the latest version it seems to be a little more inconsistent with how fast it connects, but there is still a delay. some days its 10 seconds other days its 30. Thanks for the update, I'm confident the team will be able to get this sorted shortly. Zli 1 Link to comment Share on other sites More sharing options...
A_F Posted June 6, 2024 Share Posted June 6, 2024 Im experiencing the same issue Desktop pc running win 11 and ethernet cable connected to the R3 directly Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted June 6, 2024 Administrators Share Posted June 6, 2024 59 minutes ago, A_F said: Im experiencing the same issue Desktop pc running win 11 and ethernet cable connected to the R3 directly It's a firmware issue so will require a fix, the only thing you can do at the moment is wait for the device to connect Link to comment Share on other sites More sharing options...
eggsmell Posted June 8, 2024 Share Posted June 8, 2024 Sorry for such a late response, I see you've already confirmed it's still an issue with the others here. Just to add, can confirm it's also happening on the newest firmware for me too. Link to comment Share on other sites More sharing options...
eggsmell Posted June 8, 2024 Share Posted June 8, 2024 Would also like to add that this is a very annoying issue when using smart lights in a home, as I have to relink them at least once a week due to the no connection while struggling to reach the internet for ~30 seconds. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted June 8, 2024 Administrators Share Posted June 8, 2024 3 hours ago, eggsmell said: Would also like to add that this is a very annoying issue when using smart lights in a home, as I have to relink them at least once a week due to the no connection while struggling to reach the internet for ~30 seconds. Change the DHCP lease to 10000, save, reboot the router then see if that happens less frequently Link to comment Share on other sites More sharing options...
clarkjo Posted June 29, 2024 Author Share Posted June 29, 2024 any update on this? Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted June 29, 2024 Administrators Share Posted June 29, 2024 We posted a new version in Early Access you can try, I don't think it has a fix for it specifically and will likely be in the next one Link to comment Share on other sites More sharing options...
clarkjo Posted August 9, 2024 Author Share Posted August 9, 2024 still no fix in 4.0.236 this is getting a little insane its been months Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted August 9, 2024 Administrators Share Posted August 9, 2024 14 hours ago, clarkjo said: still no fix in 4.0.236 this is getting a little insane its been months If it's not in the change log it won't have been added - we're focusing on a disconnect issue at the moment, which as I'm sure you can agree takes priority hence why there hasn't been a firmware for a little while. Link to comment Share on other sites More sharing options...
clarkjo Posted August 9, 2024 Author Share Posted August 9, 2024 the question is when will this issue gain priority. i understand there are many bugs to go through but cant you understand my frustration waiting this long on something that i haven't had an issue with on any other router except this one Link to comment Share on other sites More sharing options...
Jazze78 Posted August 9, 2024 Share Posted August 9, 2024 I have the same problem with my xbox serie x. If i have the xbox direct connect to the r3 it´s take up to 30 sec to get internet. But if i have the xbox connect to a switch first before the r3 it´s connect direct to internet. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted August 9, 2024 Administrators Share Posted August 9, 2024 That's entirely up to the devs, if they can squeeze it into the next update they will Link to comment Share on other sites More sharing options...
clarkjo Posted September 14, 2024 Author Share Posted September 14, 2024 issue is still present on v4.0.285 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted September 14, 2024 Administrators Share Posted September 14, 2024 1 hour ago, clarkjo said: issue is still present on v4.0.285 If it's not shown in the change log it won't be included - as you can tell from the topic the focus was to resolve the slowing speeds issue and still focusing on the disconnects, they'll come to this not to worry. Link to comment Share on other sites More sharing options...
clarkjo Posted September 15, 2024 Author Share Posted September 15, 2024 should i start a new thread in the early access section too for more awareness Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted September 15, 2024 Administrators Share Posted September 15, 2024 No need, they are already aware and I will chase them on it as well. Link to comment Share on other sites More sharing options...
