Naresh Posted December 13, 2023 Posted December 13, 2023 I've been facing this issue for 2 days now. I closed the tab and waited four minutes and it did not work, rebooted the router but it did not work either. I'm on the latest Beta build, not sure what is causing it suddenly, is there any way to fix it without having to reset the router or reinstall the firmware?
Administrators Netduma Fraser Posted December 13, 2023 Administrators Posted December 13, 2023 Not really no, generally a reboot will work. If you reinstall the firmware from 192.168.1.1/adv_index.htm you don't need to factory reset after so settings should be preserved
Rithveek Posted February 14 Posted February 14 Dude.... even after reinstalling the firmware the same error message is showing as : dumaos is loading... this could take up to four minutes. please wait. if this takes more than four minutes, try rebooting your router to get back to dumaos. tr-1 th-0 dr-0 I had used ur link reinstalled the firmware but again getting the same god damm message everytime. Please suggest ?
Administrators Netduma Fraser Posted February 14 Administrators Posted February 14 3 hours ago, Rithveek said: Dude.... even after reinstalling the firmware the same error message is showing as : dumaos is loading... this could take up to four minutes. please wait. if this takes more than four minutes, try rebooting your router to get back to dumaos. tr-1 th-0 dr-0 I had used ur link reinstalled the firmware but again getting the same god damm message everytime. Please suggest ? Which router and firmware version are you on exactly?
Administrators Netduma Fraser Posted February 16 Administrators Posted February 16 Do a factory reset from the interface, close the interface, wait 4 minutes then access and see if it is more consistent after that
vft1 Posted March 4 Posted March 4 This has happened to me also. Tried different browsers, computers. version 2.3.4.148 Seems like the firmware is disabling access to any administration login due to DumaOs not being able to load. http://192.168.1.1/dumaweb/ DumaOS is not running! DumaOS will not load, to be able to login. "factory reset from the interface, close the interface, wait 4 minutes" Still cannot get in, you need to fix your firmware!
Administrators Netduma Fraser Posted March 5 Administrators Posted March 5 17 hours ago, vft1 said: This has happened to me also. Tried different browsers, computers. version 2.3.4.148 Seems like the firmware is disabling access to any administration login due to DumaOs not being able to load. http://192.168.1.1/dumaweb/ DumaOS is not running! DumaOS will not load, to be able to login. "factory reset from the interface, close the interface, wait 4 minutes" Still cannot get in, you need to fix your firmware! Did the previous version work for you? That's not an update we did, just security from NTGR. You can access the settings using 192.168.1.1/adv_index.htm even if DumaOS isn't loading. Otherwise: Go to the System Information page On the "Installed Rapps" panel on the right of the screen click the icon, Change the retries to 5 Reboot the router from the interface Close the interface Wait 4 minutes Then try accessing please and see if that resolves it.
vft1 Posted March 5 Posted March 5 The previous version worked fine. So did this one for a while until now. I downloaded it soon after it came out. Thanks for "192.168.1.1/adv_index.htm" I can get in now! Dumaos still not loading , tried reuploading 2.3.4.148, still can't load DumaOS "Go to the System Information page" I have no idea how to get there? tried many different menus, could not find "installed Rapps" panel anywhere. Here are the log errors: Thursday, March 05, 2026 00:15:53 [DumaOS] Exception caught in cleanup 'com.netdumasoftware.procmanager': ERROR: Ubus error: 4 stack traceback: ^I?: in function March 05, 2026 00:15:53 [DumaOS] Exception caught in cleanup 'com.netdumasoftware.hybridvpn': bad argument #1 to 'ipairs' (table expected, got nil) -> [DumaOS] kill 2 sent to 'com.netdumasoftware.config', Thursday, March 05, 2026 00:15:53 [DumaOS] kill 2 sent to 'com.netdumasoftware.networkmonitor', Thursday, March 05, 2026 00:15:53 [DumaOS] kill 2 sent to 'com.netdumasoftware.hybridvpn', Thursday, March 05, 2026 00:15:53 [DumaOS] skipping 'com.netdumasoftware.autoadmin', Thursday, March 05, 2026 00:15:53 [DumaOS] App 'com.netdumasoftware.systeminfo' cleanup finished, Thursday, March 05, 2026 00:15:53 [DumaOS] kill 2 sent to 'com.netdumasoftware.systeminfo', Thursday, March 05, 2026 00:15:53 [DumaOS] skipping 'com.netdumasoftware.neighwatch', Thursday, March 05, 2026 00:15:53 [DumaOS] kill 2 sent to 'com.netdumasoftware.pingheatmap', Thursday, March 05, 2026 00:15:53 [DumaOS] App 'com.netdumasoftware.internetmeasurer' cleanup finished, Thursday, March 05, 2026 00:15:53 [DumaOS] kill 2 sent to 'com.netdumasoftware.internetmeasurer', Thursday, March 05, 2026 00:15:53 [DumaOS] kill 2 sent to 'com.netdumasoftware.adblocker', Thursday, March 05, 2026 00:15:53 [DumaOS] kill 2 sent to 'com.netdumasoftware.benchmark', Thursday, March 05, 2026 00:15:53 [DumaOS] Exception caught in cleanup 'com.netdumasoftware.qos': ERROR: Ubus error: 4 stack traceback: ^I?: in function '__new__, [DumaOS] kill 2 sent to 'com.netdumasoftware.qos', Thursday, March 05, 2026 00:15:53 [DumaOS] kill 2 sent to 'com.netdumasoftware.trafficcontroller', Thursday, March 05, 2026 00:15:53 [DumaOS] kill 2 sent to 'com.netdumasoftware.geofilter', Thursday, March 05, 2026 00:15:53 [DumaOS] Exception caught in 'com.netdumasoftware.procmanager': ERROR: Ubus error: 4 stack traceback: ^I?: in function '__new__, [DumaOS] App 'com.netdumasoftware.desktop' cleanup finished, Thursday, March 05, 2026 00:15:53 [DumaOS] Exception caught in 'com.netdumasoftware.desktop': cannot open //dumaos/themes/cloud: No such file or directory -> sta, [DumaOS] App 'com.netdumasoftware.qos' initialised & starting., Thursday, March 05, 2026 00:15:53 [DumaOS] Waiting for 'com.netdumasoftware.autoadmin' to run before starting, Thursday, March 05, 2026 00:15:53 [DumaOS] Waiting for 'com.netdumasoftware.devicemanager' to run before starting, Thursday, March 05, 2026 00:15:53 [DumaOS] Ubus object 'com.netdumasoftware.procmanager' added, attempting to bind pending, Thursday, March 05, 2026 00:15:51 [DumaOS] App 'com.netdumasoftware.procmanager' initialised & starting., Thursday, March 05, 2026 00:15:51 [DumaOS] Non-existent publish method 'licence_permitted', Thursday, March 05, 2026 00:15:51 [DumaOS] DumaWeb 'new' directory exists, but no index found for 'com.netdumasoftware.speedtest, Thursday, March 05, 2026 00:15:5 [DumaOS] DumaWeb index 'rapp' does not match 'com.netdumasoftware.speedtest', Thursday, March 05, 2026 00:15:50 [DumaOS] DumaWeb 'new' directory exists, but no index found for 'com.netdumasoftware.setup', Thursday, March 05, 2026 00:15:50 [DumaOS] DumaWeb index 'rapp' does not match 'com.netdumasoftware.setup', Thursday, March 05, 2026 00:15:50 [DumaOS] DumaWeb 'new' directory exists, but no index found for 'com.netdumasoftware.qos', Thursday, March 05, 2026 00:15:50 [DumaOS] DumaWeb index 'rapp' does not match 'com.netdumasoftware.qos', Thursday, March 05, 2026 00:15:50 [DumaOS] DumaWeb 'new' directory exists, but no index found for 'com.netdumasoftware.pingtest, Thursday, March 05, 2026 00:15:50 [DumaOS] DumaWeb index 'rapp' does not match 'com.netdumasoftware.pingtest', Thursday, March 05, 2026 00:15:50 [DumaOS] DumaWeb 'new' directory exists, but no index found for 'com.netdumasoftware.pingheatmap, Thursday, March 05, 2026 00:15 [DumaOS] DumaWeb index 'rapp' does not match 'com.netdumasoftware.pingheatmap', Thursday, March 05, 2026 00:15:50 [DumaOS] DumaWeb 'new' directory exists, but no index found for 'com.netdumasoftware.morefeatures, Thursday, March 05, 2026 00:1 [DumaOS] DumaWeb index 'rapp' does not match 'com.netdumasoftware.morefeatures', Thursday, March 05, 2026 00:15:50 [DumaOS] DumaWeb 'new' directory exists, but no index found for 'com.netdumasoftware.geofilter, Thursday, March 05, 2026 00:15:5 [DumaOS] DumaWeb index 'rapp' does not match 'com.netdumasoftware.geofilter', Thursday, March 05, 2026 00:15:50 [DumaOS] DumaWeb 'new' directory exists, but no index found for 'com.netdumasoftware.dashboard, Thursday, March 05, 2026 00:15:5 [DumaOS] DumaWeb index 'rapp' does not match 'com.netdumasoftware.dashboard', Thursday, March 05, 2026 00:15:50 [DumaOS] DumaWeb 'new' directory exists, but no index found for 'com.netdumasoftware.adblocker, Thursday, March 05, 2026 00:15:5 [DumaOS] DumaWeb index 'rapp' does not match 'com.netdumasoftware.adblocker', Thursday, March 05, 2026 00:15:50 [DumaOS] DumaWeb 'new' directory exists, but no index found for 'com.netdumasoftware.websettings, Thursday, March 05, 2026 00:15 [DumaOS] DumaWeb index 'rapp' does not match 'com.netdumasoftware.websettings', Thursday, March 05, 2026 00:15:50 [DumaOS] DumaWeb 'new' directory exists, but no index found for 'com.netdumasoftware.networkmonitor, Thursday, March 05, 2026 00 [DumaOS] DumaWeb index 'rapp' does not match 'com.netdumasoftware.networkmonitor', Thursday, March 05, 2026 00:15:50 [DumaOS] DumaWeb 'new' directory exists, but no index found for 'com.netdumasoftware.devicemanager, Thursday, March 05, 2026 00: [DumaOS] DumaWeb index 'rapp' does not match 'com.netdumasoftware.devicemanager', Thursday, March 05, 2026 00:15:50
Administrators Netduma Fraser Posted March 5 Administrators Posted March 5 You'll need to get main access back first so if you can literally never get it to load then either re-install the firmware from the Settings or downgrade to the previous version then you can do it from the DumaOS interface and try to upgrade back
vft1 Posted March 5 Posted March 5 tried reuploading 2.3.4.148, still can't load DumaOS Tried XR500-V2.3.2.134 same problem. From the errors, it looks like some files got deleted somehow?
Administrators Netduma Fraser Posted March 5 Administrators Posted March 5 The only solutions for the issue are: Upgrading/downgrading The retries (assuming you can access once) Reboot & waiting 4 minutes without accessing the interface Factory Reset & waiting 4 minutes without accessing the interface A combination of the above Potentially accessing via the DumaOS app might work but unlikely It's not deleted anything it's just stuck in a weird state and one or more of the things above will clear it given enough tries/time. You could try our beta firmware also that might be better: https://forum.netduma.com/topic/51611-new-xr500-beta-firmware-33535/
