Aoes Posted November 27, 2023 Posted November 27, 2023 So I recently installed my rx1000v2 fully updated firmware all that stuff tried every band changed several settings factory reset nothing seems to work did I get a broken one or what!? NETGEAR cs is useless
Administrators Netduma Fraser Posted November 28, 2023 Administrators Posted November 28, 2023 What speeds do you pay for/receive? What speeds are you getting via ethernet on speedtest.net and what are you getting on 5GHz?
Aoes Posted November 29, 2023 Author Posted November 29, 2023 I have starlink so it’s got a lot of fluctuations 50-400mbps is a typical day however my 2.4gh is 2x what the 5ghz has been getting regardless of time and connection speeds or distance from the router
Administrators Netduma Fraser Posted November 29, 2023 Administrators Posted November 29, 2023 5GHz is more susceptible to interference, in relation to the router location where are you trying to use 5GHz? Could you provide a screenshot of your QoS page please?
