xmacx7 Posted November 6, 2023 Posted November 6, 2023 Dears, While trying to make the test speed through speedtest.net, The result is 500 Download and 120 upload, but when I am trying to make the speed test through the NetGear RX1000 at Connection Benchmark, just give me 200MB Download and 120MB upload. At the QOS shale put the 500MB or 200MB? Your support please? Thanks
Administrators Netduma Fraser Posted November 6, 2023 Administrators Posted November 6, 2023 Connection Benchmark uses different servers so won't always show correctly so you can ignore it and use the 500 value.
M4G1CM1K3 Posted November 25, 2023 Posted November 25, 2023 On 11/7/2023 at 1:17 AM, Netduma Fraser said: Connection Benchmark uses different servers so won't always show correctly so you can ignore it and use the 500 value. What servers do they use?
Administrators Netduma Fraser Posted November 25, 2023 Administrators Posted November 25, 2023 6 hours ago, M4G1CM1K3 said: What servers do they use? We use https://speed.measurementlab.net/#/ for the speed test aspect
