BuddyBren Posted August 24, 2023 Posted August 24, 2023 Hey there, 1st Question) Is this an issue? On the dumaOS it is stating that I am connected to my desired VPN config file but it shows "N/A" under Provider, Country, City, and Protocol. 2nd Question) Are the WARNINGS problems that I need to solve? Here is my config file, in case its needed) client verb 1 dev tun auth-user-pass persist-key persist-tun nobind <ca> -----BEGIN CERTIFICATE----- MIIE6DCCA9CgAwIBAgIJAMjXFoeo5uSlMA0GCSqGSIb3DQEBCwUAMIGoMQswCQYD VQQGEwJISzEQMA4GA1UECBMHQ2VudHJhbDELMAkGA1UEBxMCSEsxGDAWBgNVBAoT D1NlY3VyZS1TZXJ2ZXJDQTELMAkGA1UECxMCSVQxGDAWBgNVBAMTD1NlY3VyZS1T ZXJ2ZXJDQTEYMBYGA1UEKRMPU2VjdXJlLVNlcnZlckNBMR8wHQYJKoZIhvcNAQkB FhBtYWlsQGhvc3QuZG9tYWluMB4XDTE2MDExNTE1MzQwOVoXDTI2MDExMjE1MzQw OVowgagxCzAJBgNVBAYTAkhLMRAwDgYDVQQIEwdDZW50cmFsMQswCQYDVQQHEwJI SzEYMBYGA1UEChMPU2VjdXJlLVNlcnZlckNBMQswCQYDVQQLEwJJVDEYMBYGA1UE AxMPU2VjdXJlLVNlcnZlckNBMRgwFgYDVQQpEw9TZWN1cmUtU2VydmVyQ0ExHzAd BgkqhkiG9w0BCQEWEG1haWxAaG9zdC5kb21haW4wggEiMA0GCSqGSIb3DQEBAQUA A4IBDwAwggEKAoIBAQDluufhyLlyvXzPUL16kAWAdivl1roQv3QHbuRshyKacf/1 Er1JqEbtW3Mx9Fvr/u27qU2W8lQI6DaJhU2BfijPe/KHkib55mvHzIVvoexxya26 nk79F2c+d9PnuuMdThWQO3El5a/i2AASnM7T7piIBT2WRZW2i8RbfJaTT7G7LP7O pMKIV1qyBg/cWoO7cIWQW4jmzqrNryIkF0AzStLN1DxvnQZwgXBGv0CwuAkfQuNS Lu0PQgPp0PhdukNZFllv5D29IhPr0Z+kwPtrAgPQo+lHlOBHBMUpDT4XChTPeAvM aUSBsqmonAE8UUHEabWrqYN/kWNHCNkYXMkiVmK1AgMBAAGjggERMIIBDTAdBgNV HQ4EFgQU456ijsFrYnzHBShLAPpOUqQ+Z2cwgd0GA1UdIwSB1TCB0oAU456ijsFr YnzHBShLAPpOUqQ+Z2ehga6kgaswgagxCzAJBgNVBAYTAkhLMRAwDgYDVQQIEwdD ZW50cmFsMQswCQYDVQQHEwJISzEYMBYGA1UEChMPU2VjdXJlLVNlcnZlckNBMQsw CQYDVQQLEwJJVDEYMBYGA1UEAxMPU2VjdXJlLVNlcnZlckNBMRgwFgYDVQQpEw9T ZWN1cmUtU2VydmVyQ0ExHzAdBgkqhkiG9w0BCQEWEG1haWxAaG9zdC5kb21haW6C CQDI1xaHqObkpTAMBgNVHRMEBTADAQH/MA0GCSqGSIb3DQEBCwUAA4IBAQCvga2H MwOtUxWH/inL2qk24KX2pxLg939JNhqoyNrUpbDHag5xPQYXUmUpKrNJZ0z+o/Zn NUPHydTSXE7Z7E45J0GDN5E7g4pakndKnDLSjp03NgGsCGW+cXnz6UBPM5FStFvG dDeModeSUyoS9fjk+mYROvmiy5EiVDP91sKGcPLR7Ym0M7zl2aaqV7bb98HmMoBO xpeZQinof67nKrCsgz/xjktWFgcmPl4/PQSsmqQD0fTtWxGuRX+FzwvF2OCMCAJg p1RqJNlk2g50/kBIoJVPPCfjDFeDU5zGaWGSQ9+z1L6/z7VXdjUiHL0ouOcHwbiS 4ZjTr9nMn6WdAHU2 -----END CERTIFICATE----- </ca> <cert> -----BEGIN CERTIFICATE----- MIIEnzCCA4egAwIBAgIBAzANBgkqhkiG9w0BAQsFADCBqDELMAkGA1UEBhMCSEsx EDAOBgNVBAgTB0NlbnRyYWwxCzAJBgNVBAcTAkhLMRgwFgYDVQQKEw9TZWN1cmUt U2VydmVyQ0ExCzAJBgNVBAsTAklUMRgwFgYDVQQDEw9TZWN1cmUtU2VydmVyQ0Ex GDAWBgNVBCkTD1NlY3VyZS1TZXJ2ZXJDQTEfMB0GCSqGSIb3DQEJARYQbWFpbEBo b3N0LmRvbWFpbjAeFw0xNjAxMTUxNjE1MzhaFw0yNjAxMTIxNjE1MzhaMIGdMQsw CQYDVQQGEwJISzEQMA4GA1UECBMHQ2VudHJhbDELMAkGA1UEBxMCSEsxFjAUBgNV BAoTDVNlY3VyZS1DbGllbnQxCzAJBgNVBAsTAklUMRYwFAYDVQQDEw1TZWN1cmUt Q2xpZW50MREwDwYDVQQpEwhjaGFuZ2VtZTEfMB0GCSqGSIb3DQEJARYQbWFpbEBo b3N0LmRvbWFpbjCBnzANBgkqhkiG9w0BAQEFAAOBjQAwgYkCgYEAxsnyn4v6xxDP nuDaYS0b9M1N8nxgg7OBPBlK+FWRxdTQ8yxt5U5CZGm7riVp7fya2J2iPZIgmHQE v/KbxztsHAVlYSfYYlalrnhEL3bDP2tY+N43AwB1k5BrPq2s1pPLT2XG951drDKG 4PUuFHUP1sHzW5oQlfVCmxgIMAP8OYkCAwEAAaOCAV8wggFbMAkGA1UdEwQCMAAw LQYJYIZIAYb4QgENBCAWHkVhc3ktUlNBIEdlbmVyYXRlZCBDZXJ0aWZpY2F0ZTAd BgNVHQ4EFgQU9MwUnUDbQKKZKjoeieD2OD5NlAEwgd0GA1UdIwSB1TCB0oAU456i jsFrYnzHBShLAPpOUqQ+Z2ehga6kgaswgagxCzAJBgNVBAYTAkhLMRAwDgYDVQQI EwdDZW50cmFsMQswCQYDVQQHEwJISzEYMBYGA1UEChMPU2VjdXJlLVNlcnZlckNB MQswCQYDVQQLEwJJVDEYMBYGA1UEAxMPU2VjdXJlLVNlcnZlckNBMRgwFgYDVQQp Ew9TZWN1cmUtU2VydmVyQ0ExHzAdBgkqhkiG9w0BCQEWEG1haWxAaG9zdC5kb21h aW6CCQDI1xaHqObkpTATBgNVHSUEDDAKBggrBgEFBQcDAjALBgNVHQ8EBAMCB4Aw DQYJKoZIhvcNAQELBQADggEBAFyFo2VUX/UFixsdPdK9/Yt6mkCWc+XS1xbapGXX b9U1d+h1iBCIV9odUHgNCXWpz1hR5Uu/OCzaZ0asLE4IFMZlQmJs8sMT0c1tfPPG W45vxbL0lhqnQ8PNcBH7huNK7VFjUh4szXRKmaQPaM4S91R3L4CaNfVeHfAg7mN2 m9Zn5Gto1Q1/CFMGKu2hxwGEw5p+X1czBWEvg/O09ckx/ggkkI1NcZsNiYQ+6Pz8 DdGGX3+05YwLZu94+O6iIMrzxl/il0eK83g3YPbsOrASARvw6w/8sOnJCK5eOacl 21oww875KisnYdWjHB1FiI+VzQ1/gyoDsL5kPTJVuu2CoG8= -----END CERTIFICATE----- </cert> <key> -----BEGIN PRIVATE KEY----- MIICdgIBADANBgkqhkiG9w0BAQEFAASCAmAwggJcAgEAAoGBAMbJ8p+L+scQz57g 2mEtG/TNTfJ8YIOzgTwZSvhVkcXU0PMsbeVOQmRpu64lae38mtidoj2SIJh0BL/y m8c7bBwFZWEn2GJWpa54RC92wz9rWPjeNwMAdZOQaz6trNaTy09lxvedXawyhuD1 LhR1D9bB81uaEJX1QpsYCDAD/DmJAgMBAAECgYEAvTHbDupE5U0krUvHzBEIuHbl ptGlcfNYHoDcD3oxYR3pOGeiuElBexv+mgHVzcFLBrsQfJUlHLPfCWi3xmjRvDQc r7N7U1u7NIzazy/PpRBaKolMRiM1KMYi2DG0i4ZONwFT8bvNHOIrZzCLY54KDrqO n55OzC70WYjWh4t5evkCQQDkkzZUAeskBC9+JP/zLps8jhwfoLBWGw/zbC9ePDmX 0N8MTZdcUpg6KUTf1wbkLUyVtIRjS2ao6qu1jWG6K0x3AkEA3qPWyaWQWCynhNDq u2U1cPb2kh5AJip+gqxO3emikAdajsSxeoyEC2AfyBITbeB1tvCUZH17J4i/0+OF TEQp/wJAb/zEOGJ8PzghwK8GC7JA8mk51DEZVAaMSRovFv9wxDXcoh191AjPdmdz zCuAv9iF1i8MUc3GbWoUWK39PIYsPwJAWh63sqfx5b8tj/WBDpnJKBDPfhYAoXJS A1L8GZeY1fQkE+ZKcPCwAmrGcpXeh3t0Krj3WDXyw+32uC5Apr5wwQJAPZwOORea C4YNfBPZN9BdHvVjOYGGUffpI+X+hWpLRnQFJteAi+eqwyk0Oi0SkJB+a7jcerK2 d7q7xhec5WHlng== -----END PRIVATE KEY----- </key> <tls-auth> # # 2048 bit OpenVPN static key # -----BEGIN OpenVPN Static key V1----- e30af995f56d07426d9ba1f824730521 d4283db4b4d0cdda9c6e8759a3799dcb 7939b6a5989160c9660de0f6125cbb1f 585b41c074b2fe88ecfcf17eab9a33be 1352379cdf74952b588fb161a93e13df 9135b2b29038231e02d657a6225705e6 868ccb0c384ed11614690a1894bfbeb2 74cebf1fe9c2329bdd5c8a40fe882062 4d2ea7540cd79ab76892db51fc371a3a c5fc9573afecb3fffe3281e61d72e915 79d9b03d8cbf7909b3aebf4d90850321 ee6b7d0a7846d15c27d8290e031e951e 19438a4654663cad975e138f5bc5af89 c737ad822f27e19057731f41e1e254cc 9c95b7175c622422cde9f1f2cfd3510a dd94498b4d7133d3729dd214a16b27fb -----END OpenVPN Static key V1----- </tls-auth> key-direction 1 remote-cert-tls server cipher AES-256-CBC route-method exe route-delay 0 route 0.0.0.0 0.0.0.0 script-security 2 explicit-exit-notify 2 proto udp remote 45.83.25.5 15021
Administrators Netduma Fraser Posted August 25, 2023 Administrators Posted August 25, 2023 To answer your questions: No that is normal when using a custom config as it can't tell those details No you can ignore these As long as it's working no need to look at the log!
BuddyBren Posted September 9, 2023 Author Posted September 9, 2023 Okay thank you, it has been working great. Netduma Fraser 1
