Hello
I got my new netduma r2 with the newest firmware for some reason i cant get my full speed
Im getting only 1/4 from what i expected
I should get around 1000/100 im getting only 250/70
When i disable qos i got around 350-400/98
Not sure what can i do more but i think its some restriction from domaos firmware not hw issue
Any help/fix?
What is your physical setup e.g. ISP modem/router > R2? Are ALL devices connected to the R2? Where are you testing speeds on Connection Benchmark or a 3rd party site? Have you entered your expected speeds in Bandwidth settings?
From gpon modem (zte f601 ) to netduma r2 router (lan-wan connection ) pppoe done via r2 router
Only phone(wifi) and laptop (lan) connected to netduma r2 router
Speed tested via speedtest.net
And netduma benchmark
Bandwidth setup (1000/1000)
It's most likely due to PPPoE, do you have another router you could use to handle PPPoE instead of the R2 then test the speeds you get?
No i dont
But i will borrow one to be sure that if its something related to netduma r2 pppoe issue
