i would like to vpn my entire network not just select services. I am using lastest firmware but do not see an option in hybird vpn am i missing something obvious?
Hello, welcome to the forum!
There isn't an easy way to apply it to the whole network as it wasn't designed for that purpose, you'd have to add each device and select Do NOT VPN these services and don't add any services, then it will apply to each device.
  • 2 weeks later...
after a month of ownership I would just say dont waste the money or buy it at all say a couple bucks more and get a real router hope this helps someone who was in position like me while reaearching. buy something that works and is more or less universal vs custom firware from netduma and uses wiregurad or hide my ass which is also british and is a poopy product
Are there particular issues you're having or features you expected etc? If you can provide feedback we can look into it further.
no, I would just be looking for a nee job if I was you. marketshare along with blunt non functionality would having me connecting more on linkedin
Guest
