Not sure why it's buggy now. Lowest distance. 0 assist.  Used to boot game and have all servers pop up.  Highlight designated server and go.
Now all the servers are blocked  even when i click and allow it rarely works.
I've resync cloud, cleared device manager.  When i finally get on a designated server usually the next time it connects to an opposite one.
XR1000
They'll all show blocked if your radius is very low, that's normal, it's best to have a few servers within your radius at least.
Try this:
  1. Quit the application/game/client completely
  2. Remove device from the Geo-Filter
  3. Give PC PlayStation Device Type in the Device Manager (if on PC)
  4. Resync from the Geo-Filter Map menu
  5. Re-add the device to the Geo-Filter with the manual option
  6. Set up the Geo-Filter how you like
  7. Wait 2 minutes
  8. Boot up application/game/client
Then see if it works better.
