W4R Posted February 5, 2023 Posted February 5, 2023 im a very noob at this, i dont have a clue. basically i was using the xr 1000 on its own ppoe connection. but as people are aware there is an issue with the congestion control/throttle . it seems netduma are looking into that. so for time being i was told to use the bt hub in conjunction with rx1000. i have no clue how to do this and without a double nat. iso far i have tried, wall- bt modem - bt hub, then from bt hub to XR. now when i go on bt hub router interface everything is working fine, but on the xr interface there is no internet, but i can access both interfaces. do i have the physical connection in the right order first of all ?
Administrators Netduma Fraser Posted February 5, 2023 Administrators Posted February 5, 2023 If you haven't removed the PPPoE details from the XR you'll need to do that, otherwise it won't get internet, then you can sort out the NAT. The DMZ section here will get you sorted for NAT: https://support.netduma.com/en/support/solutions/articles/16000076587-dumaos-optimal-settings-guide-open-nat
