Setting IP outside DHCP?
Hi,
I tried setting my xbox ip outside the dhcp list. It will not recognize the address.
I currently have the xbox ip set up inside dhcp and reserved.
Is there any benefit in performance going outside the dhcp list?
2 minutes ago, Ivanbad said:
Hi,
What was the IP that you set exactly? No not really unless you're having issues with DHCP specifically
23 minutes ago, Ivanbad said:
DHCP goes to 255. I tried 256 bux xbox said not recognized cuz outside range.
That won't work, you'd need to adjust the range on DHCP then set a value outside that under 256
