Connection Benchmark Test only half download speed
I would appreciate some assistance troubleshooting this issue.  I can't figure out why I'm only getting half of my download speed through the connection benchmark test.  The router determined the actual download speeds during the initial setup.  after which I consistently only get half that speed through the connection benchmark.  If I run the test on any other site, even while connected to the router, I get the correct speeds.  Here are the steps I've taken thus far:
  • Disable QOS
  • Ran several tests after adjusting sliders incrementally
  • Reset router (erased old settings)
I've searched all the forums I could find and exhausted YouTube searches.  Any assistance would be appreciated.
Thanks
They use different servers and we're still improving the results, don't worry it won't be limiting you at all, if you get your speeds from other sites then you're good to go.
