Mostwest Posted November 11, 2022 Posted November 11, 2022 How is possible I can't find an Import, export setting basic feature and why is so difficulte to implement LED on or off feature? Is it too much to ask for a 200 €/$ router?
Administrators Netduma Fraser Posted November 12, 2022 Administrators Posted November 12, 2022 There is no export/import feature for the entire router but it has been suggested, as well as the LEDs on/off, they're on our roadmap so we plan to implement them in the future.
killianbell Posted January 30, 2023 Posted January 30, 2023 On 11/12/2022 at 11:41 AM, Netduma Fraser said: There is no export/import feature for the entire router but it has been suggested, as well as the LEDs on/off, they're on our roadmap so we plan to implement them in the future. Is there a timeline on the LED feature at all? I'd really like the ability to disable them or dim then considerably.
Administrators Netduma Fraser Posted January 30, 2023 Administrators Posted January 30, 2023 5 minutes ago, killianbell said: Is there a timeline on the LED feature at all? I'd really like the ability to disable them or dim then considerably. No timeline unfortunately, I seem to remember that someone did look into it and it's not as easy a job as it sounds.
