GrumpyOldMan Posted November 4, 2022 Posted November 4, 2022 After updating firmware to the latest 3.2 on my R2 and I done the factory reset now when I try to load up the interface one getting DUmaOS not running on the web browser I also tried the app
Administrators Netduma Fraser Posted November 4, 2022 Administrators Posted November 4, 2022 Sorry to hear you're having this issue. What device/web browser are you using to access the interface in the first screenshot? While connected to the router via a Windows PC, open command prompt, type ipconfig press enter and then post a screenshot of the results here please.
GrumpyOldMan Posted November 4, 2022 Author Posted November 4, 2022 i have to hook it back up i got so frustrated after messing with for hours
Administrators Netduma Fraser Posted November 4, 2022 Administrators Posted November 4, 2022 Do post back when you can get that information, I'll be here over the weekend so no rush
GrumpyOldMan Posted November 5, 2022 Author Posted November 5, 2022 Just hooked everything back up what do i need to be looking for
Administrators Netduma Fraser Posted November 5, 2022 Administrators Posted November 5, 2022 While connected to the router via a Windows PC, open command prompt, type ipconfig press enter and then post a screenshot of the results here please.
