Loose connection to Hub 3 when i reboot xr500 help.
I am having a issue with my xr500 loosing connection to my Virgin hub 3 when i reboot the xr500.
I've got the Hub set in modem mode and have the xr500 setup to get the ip dynamically but after a reboot the WAN ip on dashboard is 0.0.0.0 and connection status is disconnected. I have to reboot the hub 3 and wait for it connect to virgin before turning the xr500 back on.
Anyone shed any light on what im doing wrong?
Thanks
Some modems/routers are particular about the order in which they are booted so it's not uncommon for that to happen. If you put the hub in router mode and put the XR WAN IP in its DMZ instead then it may stop that happening.
