philo3391 Posted October 21, 2022 Posted October 21, 2022 Hi, I play on ps5 and have attached my settings. i only play FPS (COD). I have upnp disabled on isp router and enabled on r2 i have ps5 in dmz on r2 obviously i am looking for the best bullet hit reg . if anyone has any experience/help/advice of their settings please advise. Thank you.
Administrators Netduma Fraser Posted October 21, 2022 Administrators Posted October 21, 2022 Just to clarify, you're not having any issues specifically, just looking for the best settings? I would recommend having a look through our optimal settings guides: https://support.netduma.com/en/support/solutions/folders/16000090646 Have you put the R2 in the DMZ on your ISP modem/router?
philo3391 Posted October 21, 2022 Author Posted October 21, 2022 hi Fraser. yes i have put the r2 in the DMZ on my ISP modem should i not ? is there any dhcp changes i could make on either router to help ?
Administrators Netduma Fraser Posted October 21, 2022 Administrators Posted October 21, 2022 What you have done is correct. There is no need to make any changes to DHCP as it will not affect your connection quality at all.
philo3391 Posted October 21, 2022 Author Posted October 21, 2022 people playing cod might react in other section is all i was thinking. ok people do make changes and have better results so ill see if anyone chimes in . a streamer was telling me he got help on this forum so ill see who replies. thanks
Administrators Netduma Fraser Posted October 21, 2022 Administrators Posted October 21, 2022 I've moved the topic for you to CoD support. Do go through the optimal settings guides as there is a lot of information there. Also, every connection is different so settings will be different for everyone so experimentation is recommended.
