justin peryea Posted October 14, 2022 Posted October 14, 2022 my upload is slow and when I run auto detect both r slow anyway to increase upload
Administrators Netduma Fraser Posted October 14, 2022 Administrators Posted October 14, 2022 That uses different servers than what you may normally use so don't worry about that result too much, enter what you expect manually, what are you getting on speedtest.net on a wired PC?
justin peryea Posted October 14, 2022 Author Posted October 14, 2022 wired in 900 over 472 pay for gig download doesn't make me mad it's upload
justin peryea Posted October 14, 2022 Author Posted October 14, 2022 verzion days line is fine but I run speed test verzion.com like they say and upload is little higher at 595
justin peryea Posted October 14, 2022 Author Posted October 14, 2022 I would like to get it a little closer 700 800 would be ok
Administrators Netduma Fraser Posted October 14, 2022 Administrators Posted October 14, 2022 Follow this guide and it should increase: https://support.netduma.com/en/support/solutions/articles/16000076586-dumaos-optimal-settings-guide-maximum-bandwidth-speeds also do you have ALL devices connected to the XR router?
justin peryea Posted October 14, 2022 Author Posted October 14, 2022 yea i got everything running through xr the only reason y I think something wrong is I get 455 upload when I do speed test on my phone
Administrators Netduma Fraser Posted October 14, 2022 Administrators Posted October 14, 2022 WiFi on your phone will almost always be slower than ethernet so make sure to use the wired speedtests as a way to tell if you're getting your speeds. After following the guide does wired speed improve?
justin peryea Posted October 15, 2022 Author Posted October 15, 2022 no upload speed still slow and almost the same speed wired and wifi shouldnt wire be way faster
Administrators Netduma Fraser Posted October 15, 2022 Administrators Posted October 15, 2022 Can you provide a screenshot of your QoS page please?
