Kevin.pal Posted October 12, 2022 Posted October 12, 2022 Hi there, I currently have the r1 would I see any difference purchasing he R2? Call of duty aspect of performance is my main focus! cheers,
Netduma Liam Posted October 13, 2022 Posted October 13, 2022 Yes, over time you'll notice the benefits with more frequent updates, leading to better categorisation and prioritisation of games like CoD. The R2 is generally much newer hardware so you should notice general improvements across the board!
Kevin.pal Posted October 13, 2022 Author Posted October 13, 2022 13 minutes ago, Netduma Liam said: Yes, over time you'll notice the benefits with more frequent updates, leading to better categorisation and prioritisation of games like CoD. The R2 is generally much newer hardware so you should notice general improvements across the board! Thanks. Would you say that’s the best option for gaming router for me? Too many options here..😅
Netduma Liam Posted October 13, 2022 Posted October 13, 2022 3 minutes ago, Swgohlegend said: Thanks. Would you say that’s the best option for gaming router for me? Too many options here..😅 Well, obviously I am going to say anything running DumaOS is your best option in terms of gaming routers! You could also look at the NETGEAR Nighthawk Pro Gaming range if you need better Wi-Fi coverage, however the R2 will receive more frequent updates with the latest features!
