Bridge Mode and download/upload speed.
Krdnt
Hi.
If I set my moden in bridge mode I get low download and upload speeds.
225 mbps Download & 0.08 mbps Upload. I have 1000 mbps connection. I know I can use DMZ method, by I prefer try with bridge for a while.
Any help?
Thanks.
In theory both methods pass traffic straight through to the R2, there is no difference in the way the R2 would behave with it, I know some implementations of bridge mode can be questionable and DMZ works better. If the only difference is bridge/DMZ and you haven't changed any settings on the R2 between the tests then bridge will be the issue.
