*XR1000* Help disabling UPNP
Hi. I have an XR1000 and would like to know how to see if  upnp is disabled. I know is enabled by default but as the UI for this router is bugged, as far as the enabled button not staying red, I can’t tell when its enabled or disabled. And I know I can try and disable it after a factory reset and it should be disabled. But I still would like a sure way of confirming it is disabled. Thanks.
It's bugged on that firmware, if you go to this link you can download the new firmware and install it. Make sure you factory reset it after the upgrade.
https://kb.netgear.com/000064837
