Valerio Posted April 6, 2022 Share Posted April 6, 2022 hi I have a problem that I try to solve. i separated the wifi lines from 2.4 and 5 ghz. the problem is that the 2.4 one appears and disappears if I try to connect it from my smartphone. if I deactivate and reactivate the wifi network from my mobile I can see the 2.4 line but after a while it disappears. however, devices that use the 2.4 wifi line and are connected to it work fine. is there any problem or does it work well? Link to comment Share on other sites More sharing options...
Netduma Liam Posted April 6, 2022 Share Posted April 6, 2022 What phone are you using? If you go to it's Wi-Fi settings, see if you can disable 'Private IP address' or 'MAC address randomisation' from it's settings, then try reconnect again. Are any devices other than this specific phone having trouble seeing the 2.4 network? Link to comment Share on other sites More sharing options...
Valerio Posted April 6, 2022 Author Share Posted April 6, 2022 hello I have a Poco f2 pro. not even my daughter's phone one xiaomi redmi note 8 see wifi 2.4 network Link to comment Share on other sites More sharing options...
Netduma Liam Posted April 6, 2022 Share Posted April 6, 2022 14 minutes ago, Valerio said: hello I have a Poco f2 pro. not even my daughter's phone one xiaomi redmi note 8 see wifi 2.4 network Could you perhaps share a screenshot of your Settings -> Setup -> Wireless setup page so we can see if there's anything amiss? Link to comment Share on other sites More sharing options...
