bosswahl Posted March 22, 2022 Posted March 22, 2022 Hello, hope this is the correct page to ask for help setting up my hma vpn on my xr500 router. All this is like trying to read ancient Egyptian lol. I enter in my hma log in credentials and select location. For protocol if I select udp it says failed and if I enter tcp it just stays saying connecting but never actually connects. Could really use some help or if possible a video to get me on my way. Any and all help would be greatly appreciated
Netduma Liam Posted March 22, 2022 Posted March 22, 2022 6 hours ago, bosswahl said: Hello, hope this is the correct page to ask for help setting up my hma vpn on my xr500 router. All this is like trying to read ancient Egyptian lol. I enter in my hma log in credentials and select location. For protocol if I select udp it says failed and if I enter tcp it just stays saying connecting but never actually connects. Could really use some help or if possible a video to get me on my way. Any and all help would be greatly appreciated Thanks for posting, with HMA you'll need to use the advanced configuration method at the moment. To do this, you'll need to download the OpenVPN configuration files from the HMA website. After that, copy and paste the entire config file of your choice into the configuration field. For full information on this, check out the below optimal settings guide. http://support.netduma.com/support/solutions/articles/16000087492--dumaos-optimal-settings-guide-hybrid-vpn
bosswahl Posted March 22, 2022 Author Posted March 22, 2022 Actually I got it figured out. It with username without email address. Once I figured that out by trial and error everything is working perfect. Thank you for your reply though
Netduma Liam Posted March 22, 2022 Posted March 22, 2022 2 hours ago, bosswahl said: Actually I got it figured out. It with username without email address. Once I figured that out by trial and error everything is working perfect. Thank you for your reply though Ah OK sure, I'll go ahead and lock the topic in that case. If you run into any other problem please do feel free to open another one.
