HasJ Posted February 9, 2022 Posted February 9, 2022 Hi, I am new to using Netduma. Got two Q's if someone can help. 1. I am connected to Netduma R2, however, out of eight, I can see only four lights switched on. Lights with labels of 1,2,3 &4 are on off 2. Have tried couple of times but peed I get through my Netduma on wireless connectivity are lower compared to BT router. There is a significant difference, do I need to make any changes in setup. (See attached). All 4 antennas are installed on router Netduma speed test.pptx
Netduma Liam Posted February 9, 2022 Posted February 9, 2022 Welcome to the forum! I'll answer your questions in points like you've listed them: The lights illuminate when traffic is detected. If there is no traffic going through that port/interface, it's light will not flash. By the sounds of things, you don't have any devices connected to the LAN ports currently using the internet. I have a few questions regarding this issue: How far are you from the R2 when performing this speed test Have you configured QoS at all? If so, could you please let me know how you've configured Congestion Control specifically? Are all devices on the network currently connected to the R2, or are some still connected to the BT hub? Let me know and we can look into that second question further!
