XR1000 Upload speed issues
I recently got fiber and the router wasn’t handling it too well so I factory reset it and I’m having the same issue, 900mbps upload initial and then drops to about 90 for a random period of time. This doesn’t take in account qos as I’ve tested it on and off and had the results.
Are you testing on Connection Benchmark or using speedtest.net for example? Are you using WiFi or ethernet to test?
It can take some time for the connection to settle in, did they provide a new modem/router? If so and you're not using it, take the MAC address from that and set it as the XR1000 MAC address in Internet Setup, that could resolve it.
