designerema Posted December 19, 2021 Posted December 19, 2021 i have a xr500 and all of a sudden the LAN stop working, it only works wifi, anyone knows why?? i though it was my ISP but its the router. thanks in advance
Administrators Netduma Fraser Posted December 19, 2021 Administrators Posted December 19, 2021 In LAN Settings set the DHCP range to start at .50 instead of .2. Then give devices reserved IPs between .2 - .49 (you can give them the IPs they already have), apply everything, reboot from the interface, wait 2 minutes before accessing and see if it is more stable after that.
designerema Posted December 19, 2021 Author Posted December 19, 2021 oh sorry i did not specified the playstation recognize de lan i just dont have intertnet connection wired, just wifi
Administrators Netduma Fraser Posted December 19, 2021 Administrators Posted December 19, 2021 59 minutes ago, designerema said: oh sorry i did not specified the playstation recognize de lan i just dont have intertnet connection wired, just wifi Yeah I think its a DHCP lease issue so if you do the above it should work after that
designerema Posted December 19, 2021 Author Posted December 19, 2021 1 hour ago, Netduma Fraser said: In LAN Settings set the DHCP range to start at .50 instead of .2. Then give devices reserved IPs between .2 - .49 (you can give them the IPs they already have), apply everything, reboot from the interface, wait 2 minutes before accessing and see if it is more stable after that. IT WORK!! thaks Fraser you are Beast!!!!
