Jlongx83 Posted November 21, 2021 Posted November 21, 2021 Can anyone chime in on the voltage and amperage of the adapter to power the router? I'm finally getting around to setting mine up and I've got a box full of adapters. Trying to not plug in the wrong one.
Administrators Netduma Fraser Posted November 21, 2021 Administrators Posted November 21, 2021 Here are the details for the adapter: 100-240V, 50-60Hz; Output: 12V, 1000mA
theparentgamers Posted September 20, 2022 Posted September 20, 2022 Do you know the diameter of the pin I need a new power supply is it 5.5 outer and 2.2 inner thank
Administrators Netduma Fraser Posted September 20, 2022 Administrators Posted September 20, 2022 1 hour ago, theparentgamers said: Do you know the diameter of the pin I need a new power supply is it 5.5 outer and 2.2 inner thank I don't have the details on that but I can ask around, did you measure the existing power supply to get those dimensions?
theparentgamers Posted September 21, 2022 Posted September 21, 2022 My dog completely chewed it I do t have one to measure
theparentgamers Posted September 21, 2022 Posted September 21, 2022 21 hours ago, Netduma Fraser said: I don't have the details on that but I can ask around, did you measure the existing power supply to get those dimensions? Hi I have brought the right power supply for it and all I'm getting is the red power light iv tried pressing the reset button on the back and still nothing
Administrators Netduma Fraser Posted September 22, 2022 Administrators Posted September 22, 2022 Does it have the same power as mentioned here: On 11/21/2021 at 7:40 PM, Netduma Fraser said: Here are the details for the adapter: 100-240V, 50-60Hz; Output: 12V, 1000mA
