Ping under load problems
Landon
when using the QOS feature my ping underload score is a D every time I have used the automatic setup and did it manually starting with 90% on both download &upload decreasing it by 10% nothing changes much my download ping is around 100 and upload is 500+ every test  I do any suggestions? My  pc is hardwired from the R2 using cat5e ive also done the same thing on a deferent pc also connected on the r2 and same results but not I'm also failing the ping test and have packet loss on that setup.  https://gyazo.com/02b0cb1efbc56e30ade4671985c62a70
What firmware version are you on and what speeds do you pay for/expect? Doesn't seem to be showing the upload speed there which is probably why the test is higher than expected.
Don't worry about the test, due to your speeds it's very easy for you to saturate the connection and for bufferbloat to happen, you're unlikely to get a great result there. What is the connection like for gaming?
non peak usage hours fine no problems but if anyone gets on the connection even just web surfing it lag spikes and packet loss are heavy
That makes sense, can you provide a screenshot of the QoS page of the settings you're currently using please? It will be hard to get it perfect due to your speeds
