Dantaniian Posted October 8, 2021 Posted October 8, 2021 Hey, i've been using netduma for a few years now and im running into a problem when i try to use Geo-Filter. whenever i try to use it with like 90% of the games the 'filtering mode' is greyed out and i can't use it. games like destiny, and call of duty (pc) i used to be able to use Geo-Filter but all of the sudden i can't use it anymore! its annoying me cause i got the router mostly for this feature. dumaOS version and firmware version: 3.0.105
Netduma Liam Posted October 8, 2021 Posted October 8, 2021 Are you able to filter games properly if you go to Device Manager, select your PC, change it's device type to 'Playstation' and then re-add it to Geo-filter?
