Disconnecting Problems
Siidv2
So i have a Netduma R2 router that i bought last year and whenever i try to connect it to my PC via ethernet, it consistently tries to connect and then disconnects.
When did you first notice this issue happening? Has anything changed regarding settings or the setup e.g. new cables etc?
I noticed this happening the other day when i tried to use my netduma again. When i first bought it i tried to set it up using the geofilter to get better ping in warzone but couldnt figure it out so i never used it since. Once i tried to use it again that is when i noticed it wouldnt connect. There was also no wifi signal
Understood thanks, I think given the circumstance and that it has been awhile it would be best to do a factory reset and setup from scratch. Hold the reset button for 30 seconds, release, wait 2 minutes then see if you can access and if WiFi shows and ethernet appears consistently
