Wifi function problem
Hello,
I contact you because I have a problem with the Wifi module.
From one day to the next, the Wifi module has become deactivated while all the parameters concerning the Wifi are activated.
Where can the problem come from ?
I already rebooted the router, reinstall the last update or the previous one, but nothing solves the problem.
I am on an XR500. Thanks in advance for your help.
Sincerely
If it's enabled in Settings but has been disabled then it means the WiFi button on the top of the router has been pressed to disable it. If you don't recall pressing it or no one in your home has done and if you have a pet it's possible they've sat on the button! If you press the button while it's not working then it should be enabled again.
Perfect, I hadn't even thought of that.
I'm looking for more complication and look only in the DumaOS board. 🤣
Thanks again!
