Problem with geo-filter
Gsantanam07
hello I have a problem with Geo-Filter the Resync Cloud does not work for me, it tells me "The operation is taking longer than expected. Please briefly wait before using this Rapp."
Welcome to the forum!
That error may appear sometimes if the resync took longer than normal, it's fine though because it still will have successfully completed the resync, just refresh the page and it will be fine.
Are you having any other issues with Geo-filter or is it just this?
83 / 5000
Resultados de traducción
ok, the other problem I have is that my nat is moderate and I have the dmz activated. the game is Call of dutty cold war
Please disable the DMZ on the R2, this isn't quite the right configuration to help with your NAT type.
Instead, access your modem's interface and find the modem's DMZ settings, put the R2 WAN IP address in here and reboot both the router and the modem.
If you're not sure how to access your modem's interface, please let me know the make and model of your modem and I'll provide instructions.
