First shot first die
L7NALMARI
What is the IP address that you're pinging exactly, is it a game server?
Google ip adress
If you use a different address such as a local news site do you see the same?
Yes the same
I don't think this is on your side, they all go through the same initial routing and there is no packet loss on the last two so I think this will be upstream and not much you can do otherwise it would happen all the time
