Administrators Netduma Fraser Posted April 4, 2021 Administrators Posted April 4, 2021 Are you referring the LAN IP that you access the router with, the WAN IP that your ISP modem/router gives the R2 or your public IP? Either way: LAN IP - You can do this from Settings > LAN WAN IP - You can do this from the LAN Settings on your ISP modem/router, then reboot the R2 from the interface Public IP - Depends whether you have a dynamic IP or not but if you do then unplug your modem from power for 10 minutes, then power up and you should have a different IP
