Problem with R2
Mulsanne
I followed the installation guide in the letter,
 my r2 turns on: power supply, internet, port 1 on my computer.
The wifi is not working and I cannot connect to the address 192.168.77.1.
and my internet box cannot see the r2 and my computer either.
C:\Users\julien>ipconfig
Configuration IP de Windows
Carte inconnue Connexion au réseau local 2 :
   Statut du média. . . . . . . . . . . . : Média déconnecté
   Suffixe DNS propre à la connexion. . . :
Carte Ethernet Ethernet :
   Adresse IPv6. . . . . . . . . . . . . .: 2a02:842b:376:3401:744a:53dd:1422:b628
   Adresse IPv6 temporaire . . . . . . . .: 2a02:842b:376:3401:a8a7:d89c:886f:2701
   Adresse IPv6 de liaison locale. . . . .: fe80::744a:53dd:1422:b628%8
   Adresse IPv4. . . . . . . . . . . . . .: 192.168.1.61
   Masque de sous-réseau. . . . . . . . . : 255.255.255.0
   Passerelle par défaut. . . . . . . . . : fe80::6235:c0ff:fe50:9b8%8
                                       192.168.1.1
C:\Users\julien>
Sorry to hear you're having this issue. Can you unplug the WAN/internet cable from the R2 that's connecting it to the modem and while still connected to your PC run another ipconfig and post the results please.
Here is
                                       192.168.1.1
C:\Users\julien>
Hold the reset button for 30 seconds, release, then wait 2 minutes and see if the WiFi appears/whether you can access 192.168.77.1 in your web browser.
Set a static IP on the PC itself using this information and this guide (control panel) https://pureinfotech.com/set-static-ip-address-windows-10/
192.168.77.2
255.255.255.0
192.168.77.1
DNS 192.168.77.1
then see if you can access the interface please.
I tried, the internet is cut and impossible to access the address of the r2, it does not work either
Could you unplug the router from power for 10 minutes please - this lets residual power drain, then connect it up and try again
hello, it still doesn't work, nothing helps. I have tried everything, impossible to access it
