Carlos30 Posted March 21, 2021 Posted March 21, 2021 Hello community, I have a situation before, I did not have a problem, this I acquired this xr1000 router to have better results, I disconnected the computer a lot, some solution
Administrators Netduma Fraser Posted March 21, 2021 Administrators Posted March 21, 2021 Hey, welcome to the forum! Is it just your PC that is disconnecting? How do you have it connected to the router, via ethernet or WiFi? If you're using WiFi are you using Smart Connect?
Carlos30 Posted March 21, 2021 Author Posted March 21, 2021 yes is only my pc . i have my smart phone conected to my regulas moden is work but never before happen this sorry my ingles short
Administrators Netduma Fraser Posted March 21, 2021 Administrators Posted March 21, 2021 Let's continue in your other topic: https://forum.netduma.com/topic/35572-nesesito-un-poco-de-ayuda/ You speak Spanish and I will use Google Translate
