Best setup for the netduma R2 when existing router is in place and you plan to keep it.
D2*
Hello,
when my netduma R2 arrives what is recommended when you have an existing router? Setup dumas as primary router and set secondary router for bridge mode.?
thanks for the help
I assume you're referring to the ISP modem/router? If so keep that as it is, connect the R2 then take the WAN IP from the R2 System Information page and put that in the ISP modem/router DMZ feature. Disable ISP router WiFi and connect all devices to the R2, then you're good to go!
