I need help badly right now I can't use anything
Ozzy
I just got my R2 and I'm going through the setup wizard it freezes on the setting up wifi screen and times out now I can't get into the router because it says my password has changed. I've tried the factory password/ new password and neither work. Please help.
Are you able to use an ethernet cable with your PC to connect to the router and complete the setup wizard? If so then do that then in WiFi settings you can change the WiFi password again and reconnect.
