QoS Problem
Cuber48
Every time I change my bandwidth to Devices instead of applications it reloads the page and changes it back to applications again(I tried multiple times).
It’s more of a loading issue keep saying I’m no longer connected every time it shows up The setting I chose doesn’t apply.
What do you mean it shows you're no longer connected, where does it show that? It won't necessarily show which one you're using on first refresh but we can definitely sort that out.
When you change the type hit the button to update bandwidth tree.
