Help
Davidkutosi
Hello I’m having some weird problems and idk if it’s cause of my isp or it’s just be being dumb but I have wifi but on my Xbox all of a sudden it’s just wonky i tried joining bo4 and I lag so bad never happens before then I looked at the network on bo4 it says my ping is like over 80ms when normally my ping would say 27ms and I also noticed how it says 3% packet loss then I tried to load up fortnite on Xbox it said an error occurred and can’t sign into Xbox live what do I do
What is your ping shown by the Geo-Filter? Have you tried direct to the ISP router to see if you experience the same issue?
What is the R2 plugged into exactly? It has to be connected to something to get internet, is it a port in the wall?
I have router connected via Ethernet to spectrum modem like all of a sudden I’m getting lag on bo4 and losing packets I think it’s called
If you look on the underside of the model it should have a model number, could you let me know what that is please?
Okay let us know when you can! Also when you're able to provide a screenshot of your Connection Benchmark results and your Geo-Filter and QoS settings please.
