iMoD1998 Posted January 14, 2021 Posted January 14, 2021 I've notice a problem with IPv6 setting on the latest beta. Even with options disabled its still assigning IPv6 addresses like the following: Not sure if its directly related but seems on linux devices, im having problems with DNS queries taking alot of time as they are expecting AAA records causing web requests to take around 5+ seconds. Ive provided a TCP dump of an example web request: tcpdump -vvv -s 0 -l -n port 53 tcpdump: listening on eth0, link-type EN10MB (Ethernet), capture size 262144 bytes 01:24:25.441601 IP (tos 0x0, ttl 64, id 58816, offset 0, flags [DF], proto UDP (17), length 57) 192.168.1.253.34549 > 1.1.1.1.53: [bad udp cksum 0xc4dd -> 0x7654!] 7015+ A? ifconfig.so. (29) 01:24:25.441613 IP (tos 0x0, ttl 64, id 58817, offset 0, flags [DF], proto UDP (17), length 57) 192.168.1.253.34549 > 1.1.1.1.53: [bad udp cksum 0xc4dd -> 0xe057!] 38499+ AAAA? ifconfig.so. (29) 01:24:25.454176 IP (tos 0x0, ttl 57, id 28155, offset 0, flags [DF], proto UDP (17), length 73) 1.1.1.1.53 > 192.168.1.253.34549: [udp sum ok] 7015 q: A? ifconfig.so. 1/0/0 ifconfig.so. [56m35s] A 54.146.53.133 (45) 01:24:26.212361 IP (tos 0x0, ttl 64, id 59565, offset 0, flags [DF], proto UDP (17), length 60) 192.168.1.253.34767 > 1.1.1.1.53: [bad udp cksum 0xc4e0 -> 0x965f!] 40193+ A? api.github.com. (32) 01:24:26.224390 IP (tos 0x0, ttl 57, id 52197, offset 0, flags [DF], proto UDP (17), length 76) 1.1.1.1.53 > 192.168.1.253.34767: [udp sum ok] 40193 q: A? api.github.com. 1/0/0 api.github.com. [15s] A 140.82.121.5 (48) 01:24:26.224430 IP (tos 0x0, ttl 64, id 59571, offset 0, flags [DF], proto UDP (17), length 60) 192.168.1.253.34767 > 1.1.1.1.53: [bad udp cksum 0xc4e0 -> 0x7f41!] 46084+ AAAA? api.github.com. (32) 01:24:26.236925 IP (tos 0x0, ttl 57, id 52200, offset 0, flags [DF], proto UDP (17), length 144) 1.1.1.1.53 > 192.168.1.253.34767: [udp sum ok] 46084 q: AAAA? api.github.com. 0/1/0 ns: github.com. [6m52s] SOA ns-1707.awsdns-21.co.uk. awsdns-hostmaster.amazon.com. 1 7200 900 1209600 86400 (116) 01:24:26.538234 IP (tos 0x0, ttl 64, id 59832, offset 0, flags [DF], proto UDP (17), length 71) 192.168.1.253.40246 > 1.1.1.1.53: [bad udp cksum 0xc4eb -> 0x881a!] 48328+ A? raw.githubusercontent.com. (43) 01:24:26.538244 IP (tos 0x0, ttl 64, id 59833, offset 0, flags [DF], proto UDP (17), length 71) 192.168.1.253.40246 > 1.1.1.1.53: [bad udp cksum 0xc4eb -> 0xad15!] 31949+ AAAA? raw.githubusercontent.com. (43) 01:24:26.549642 IP (tos 0x0, ttl 57, id 55967, offset 0, flags [DF], proto UDP (17), length 170) 1.1.1.1.53 > 192.168.1.253.40246: [udp sum ok] 48328 q: A? raw.githubusercontent.com. 5/0/0 raw.githubusercontent.com. [23s] CNAME github.map.fastly.net., github.map.fastly.net. [23s] A 151.101.0.133, github.map.fastly.net. [23s] A 151.101.192.133, github.map.fastly.net. [23s] A 151.101.64.133, github.map.fastly.net. [23s] A 151.101.128.133 (142) 01:24:30.446231 IP (tos 0x0, ttl 64, id 62125, offset 0, flags [DF], proto UDP (17), length 57) 192.168.1.253.34549 > 1.1.1.1.53: [bad udp cksum 0xc4dd -> 0x7654!] 7015+ A? ifconfig.so. (29) 01:24:30.463758 IP (tos 0x0, ttl 57, id 31815, offset 0, flags [DF], proto UDP (17), length 73) 1.1.1.1.53 > 192.168.1.253.34549: [udp sum ok] 7015 q: A? ifconfig.so. 1/0/0 ifconfig.so. [56m27s] A 54.146.53.133 (45) 01:24:30.463804 IP (tos 0x0, ttl 64, id 62132, offset 0, flags [DF], proto UDP (17), length 57) 192.168.1.253.34549 > 1.1.1.1.53: [bad udp cksum 0xc4dd -> 0xe057!] 38499+ AAAA? ifconfig.so. (29) 01:24:30.475736 IP (tos 0x0, ttl 57, id 31826, offset 0, flags [DF], proto UDP (17), length 134) 1.1.1.1.53 > 192.168.1.253.34549: [udp sum ok] 38499 q: AAAA? ifconfig.so. 0/1/0 ns: ifconfig.so. [22m37s] SOA ns1.p16.dynect.net. admin.samuelkadolph.com. 2020111000 3600 600 604800 1800 (106) 01:24:31.542697 IP (tos 0x0, ttl 64, id 62832, offset 0, flags [DF], proto UDP (17), length 71) 192.168.1.253.40246 > 1.1.1.1.53: [bad udp cksum 0xc4eb -> 0x881a!] 48328+ A? raw.githubusercontent.com. (43) 01:24:31.554259 IP (tos 0x0, ttl 57, id 58506, offset 0, flags [DF], proto UDP (17), length 170) 1.1.1.1.53 > 192.168.1.253.40246: [udp sum ok] 48328 q: A? raw.githubusercontent.com. 5/0/0 raw.githubusercontent.com. [17s] CNAME github.map.fastly.net., github.map.fastly.net. [17s] A 151.101.64.133, github.map.fastly.net. [17s] A 151.101.192.133, github.map.fastly.net. [17s] A 151.101.0.133, github.map.fastly.net. [17s] A 151.101.128.133 (142) 01:24:31.554299 IP (tos 0x0, ttl 64, id 62835, offset 0, flags [DF], proto UDP (17), length 71) 192.168.1.253.40246 > 1.1.1.1.53: [bad udp cksum 0xc4eb -> 0xad15!] 31949+ AAAA? raw.githubusercontent.com. (43) 01:24:31.566468 IP (tos 0x0, ttl 57, id 58517, offset 0, flags [DF], proto UDP (17), length 164) 1.1.1.1.53 > 192.168.1.253.40246: [udp sum ok] 31949 q: AAAA? raw.githubusercontent.com. 1/1/0 raw.githubusercontent.com. [22s] CNAME github.map.fastly.net. ns: fastly.net. [22s] SOA ns1.fastly.net. hostmaster.fastly.com. 2017052201 3600 600 604800 30 (136) This issue is alleviated only when forcing curl to work in IPv4 mode. This device also does not have an IPv6 address, which makes this even more confusing. eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.1.253 netmask 255.255.255.0 broadcast 192.168.1.255 ether XX:XX:XX:XX:XX:XX txqueuelen 1000 (Ethernet) RX packets 382473 bytes 29037121 (27.6 MiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 296761 bytes 14461330039 (13.4 GiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 92 lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 117 bytes 11651 (11.3 KiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 117 bytes 11651 (11.3 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 Any help would be apricated. If it helps any more this was taken from an unraid server thats using the 10GB sfp+ port. I've also experienced this problem on other linux based devices like a raspberry pi aswell.
Administrators Netduma Fraser Posted January 14, 2021 Administrators Posted January 14, 2021 This issue is actually present on the XR500 beta as well so I will add it to that ticket so the devs can take a look.
