Davidkutosi Posted January 9, 2021 Posted January 9, 2021 Hello me again I finally setup my router but 1 day later I’m having problems wirelessly I keep getting lag spikes and I tried using Ethernet to my Xbox but nothing changed it was the same not sure what to do but pls help? And idk how to setup a vpn or add device
Davidkutosi Posted January 9, 2021 Author Posted January 9, 2021 Also I keep randomly getting disconnected
Administrators Netduma Fraser Posted January 9, 2021 Administrators Posted January 9, 2021 Have you setup the Geo-Filter or QoS at all to optimize the connection? Could you provide a screenshot of your Connection Benchmark results please? Are you using mirror mode for WiFi? If so disable, then give 2.4/5GHz different names and connect manually to each of those and see if that improves. Also are you on the .179 firmware?
