Geo filter problems PS4 Destiny 2 xr500
Hi, Im having issues with the geo fillter on the xr500
It used to work find around this time last year. I havent tried it since then but i needed to use it again but it dont work
I use it on PS4 for Destiny 2. I used to be able to load in solo when going to the tower or a stike but now i always get populated lobbies
Ive tried removing my ps4 from device manager and adding it back. It setup as console and the destiny profile. All checkboxes are off as they should be because D2 is a peer to peer game.
I am connected via wifi and this was sucsessfuly geo filetering this time last year.
Has anyone got any ideas ?
Thanks
Due to some recent updates from Destiny the Geo-Filter doesn't filter for it as well as it once did. It is not as simple as doing a cloud update this time to rectify it. It will take actual changes to the Geo-Filter, we need to investigate and implement, this will take some time so best to either continue trying to filter with strict mode on perhaps or use spectating mode.
That’s strange because my friend can solo load into a tower using the same hardware as me.
he’s also on PS4 and xr500.
The only thing that’s changed for me is my ISP.
I’m in UK
i used to be on BT  and it worked
I’m currently on Virgin
could this me an issue ?
I wouldn't have thought so, have you mirrored the exact settings he is using? Are you on different firmware versions?
Same firmware and same setting.
This is why it’s so frustrating.
When I first bought the xr500 it would work will all default setting too; just filter and choose a remote location
 might try a factory reset to see if that helps anything.
I'm not sure how theirs is actually working correctly as it shouldn't at all. What do you actually see on the map when trying to filter?
Very strange indeed.
it’s working now  weird
on the map I see lots of triangles of people trying to join a public area like tower or destination
but... it never works when I also use my netgear nighthawk mesh Extender S65
any ideas for this dilemma ?
