Is WIFI required to use Netduma ?
papakiriakou
Hello everyone, want to clarify if Wifi is needed to use Netduma, as I am having a PC and not a laptop. Hence, it is not provided with Wifi, should only ethernet can work?
Yes you can plug the PC into the router via ethernet, you're not required to use the WiFi to establish an internet connection.
